Super noob question
I would like to ask a very simple question. I have a shape (attached) and I would like to bend it into a ring shape so it becomes a hollow cylinder with the scalloped edges at the bottom. What would be the appropriate command to use for this?
Thanks :)grin:
I’m not an expert yet so I don’t know if this is the best method, but using _flow?
It’ll warp the original shape though…
Flow.3dm (218.3 KB)
FlowAlongSrf after creating a cylinder to flow along, or you might try Bend.
Both are likey to require some experimentation. It may be simpler to form half a cylinder and then use Mirror for a full cylinder.
Wow, thank you so much for the example! :slight_smile: I will give it a try.
Thank you for taking the time to answer. I will try both suggestions. All help is greatly appreciated. :slight_smile:
