Sunsystem Broken when importing a SKP-file with a GeoLocation
Sunsystem Broken when importing a SKP-file with a GeoLocation such as Seattle. The Lattitude and Longitude values are correct, but the timezone slider is wrong when you are located in Europe. If you change the location to Europe and back to Seattle, the problem is fixed, but it should not be needed.
NB. In SketchUp it is possible to set a North Direction similar to in Rhino, but it is not respected or the model is imported in a different orientation. Maybe it is related to the SketchUp user has moved the Axis (CPlane)?
< VS >
UPDATE: The issue is not related to SKP-files. It looks like it has not been fully tested in BETA. Relocation a model from USA to Europe or elsewhere should update the diffence between Local Time and UTC. It should obviously also be tested relocating a model from Northern to Southern hemisphere should affect the Calendar (Winter and Summer). Test: Seattle, Barcelona, Sydney
