Sun activity not showing up correctly, sun setting too early
Hey rhino community, does anyone else run into this? I’m trying to run a sun study set to mid august 2022 for a house and for some reason the sun is setting like an hour earlier than it should. After checking this sunrise/ sunset log the sun is just not setting or rising at the right time. Sunrise Sunset log
Anything I can check in my properties panel (mac) to get the most correct sun locations?
Best,
A
Hello- is Daylight Saving time getting into the mix?
I’m not sure, I have mine set to 0 at the moment. Is that the correct setting?
Hi Aluna -
That depends on the location and the date.
I see you are in New York, if that’s the location, you’ll need 60 minutes for dates between March 13th and November 6th, 2022.
