Sums in BoxEdit
Does anyone know if any way to do simple sums in the BoxEdit input box.
For instance, if I want to add an extra 37mm to the X-size is there anyway to do right in the box?
Thanks
Type “+37” after the current dimension in the input field.
Yeah, that doesn’t work tried that already. Cheers anyway
Hi @dylanbahnan
Works here on R6, SR20. Are you not seeing any effect?
Edit: Be sure to leave the existing dimension intact and just add +37 after or 37+ before.
-Jakob
Ah, @Normand I’m using R5. Maybe its a new thing for R6.
Hi @dylanbahnan
Yeah, sorry. Just tested it in R5 - it seems like it’s an added feature in R6.
-Jakob
No worries, looks like it was somthing that came with this: https://www.rhino3d.com/6/new/refinements#command-line-math
Thanks for checking!
