Suggestions for & Feedback on the AI Panel
So, I tested the AI Panel a bit and wanted to share some feedback:
  1. Quick model switching
    I’d like to be able to switch models depending on the task, not only between providers like Claude and Codex, but also between different models within Codex, for example Astra, Sol, etc. For a simple task like creating a 50 × 50 × 50 mm box, there is no need to use Astra. Switching models should therefore be quick and accessible directly from the AI Panel, without having to go into the settings every time.
  2. Codex model configuration
    Rhino automatically detected a Codex setup and selected ChatGPT (5.5) by default. However, when running a prompt, I received the following message:
    “Codex: Model metadata for gpt-5.5 not found. Defaulting to fallback metadata; this can degrade performance and cause issues. Codex failed: The ‘gpt-5.5’ model is not supported when using Codex with a ChatGPT account.”
    So it seems that somewhere in the automatic setup or model validation, compatibility is not being checked correctly.
  3. Account transparency and switching
    I have both a private ChatGPT account and a company ChatGPT account. In the settings, it is currently not clear to me which account Codex is actually using and, consequently, which account is being billed. I would expect the AI Panel to clearly show something like “Codex connected with Account X” and ideally provide an easy way to switch between accounts.
  4. Token / usage transparency
    As an AI user, I really need visibility into my remaining tokens or usage allowance. Even more importantly, I need to develop a feeling over time for how much different tasks and models consume. Ideally, the AI Panel would show both the remaining allowance and the approximate consumption per request. This would help me understand whether a task is worth running with a more powerful model or whether a smaller and more efficient model is sufficient.
This is really good feedback @MartinIC, thanks for the writeup!
→ RH-99908 Make model switching easier
→ RH-99909 Show which account is logged in
→ RH-99911 Codex: Model metadata for gpt-5.5 not found
→ RH-99913 Token Usage
