Suggestion: Suspend Groups
I love groups but I often end up finding it easier to put items into a Block so I can at least Isolate items in the group i want to amend.
However, this can get annoying if I don’t necessarily like to have to put so many items in blocks. It would be easier if there was a ‘SuspendGroups’ toggle to turn groups on and off.
For Example you could:
Toggle ‘SuspendGroups’ work on a specific item, then toggle ‘SuspendGroups’ again and the object is back in that group.
I know on PC you can CTRL+SHIFT click an item and you can also remove an item from Group but I feel this minor addition would be so helpful.
Thanks for consideration
Hi @Christian_Young,
You can pick objects in a group by pressng Shift+Ctrl and then clicking on what you want to select.
– Dale
Thanks Dale, I did say in my post i know this is an option…?
Sorry, I was was running out the door when I replied.
The suspend groups feature is on the list. I’ll make note that another user is interested.
https://mcneel.myjetbrains.com/youtrack/issue/RH-1045
Thanks,
– Dale
interesting topic… could you make the tracker public?
