Suggestion : Invisible hatch or wipeout for 2d block symbols
With an option for making a hatch invisible and used in a block , it gives the possibility to hide content below the hatch and this has a few uses:
  • P&ID diagrams and similar the “line” element can be continuous below the symbols:
Similar this is useful for other kinds of diagrams type drawings and for callout
ballons etc.
  • 2d assembly drawings can be implemented with manipulating the draw order
    of the blocks. For example a shaft with bearings and components where the
    shaft is below all other blocks.
In AutoCAD there is an option to use a “wipeout” element for this.
Other software implement this with a invisible hatch.
I did not find any possibility to implement this with the current toolset in Rhinoceros,
but I might be wrong here.
Hei rute -
We have that feature request on the heap as RH-73639 - Polyline Mask for objects (WIPOUT)
This item is not visible to the public.
In the case of your valve on the hydraulic line, when you include a white hatch in the valve block, you can use the SendToBack command on the line to make that not show up through the block.
One should be able to use BringToFront on the block object but that doesn’t currently work:
RH-35705 Apply to block instances
Excellent.
I did some testing myself and probably hit the issue RH-35705, as
I remember I could not get it to work properly with draw order.
The work around is easy here, but could be an issue with many
overlapping blocks.
