Suggestion: Grasshopper NODE MAPS
Hi McNeel,
Recently I’ve tried ComfyUI, typically a Grasshopper version for AI Image Gen. In ComfyUI, there is a feature called “NODE MAPS”. Basically, it is the tab that allows users to see groups of nodes in a clean, systematic, and intuitive way, instead of finding workflow in between connect lines. I’m wondering if there will be a Grasshopper’s NODE MAPS version. Many thanks.
A screenshot or something might help people understand what you’re talking about.
Oh yeah, my bad. I attached it.
On the canvas, there are 4 groups, sequentially: Loader, CLIP, Sampler, and Result. And at the same time, on the left-hand panel, it displays that 4 group. And when you click on each of it, it displays the components of the groups, and allows you to switch on/off the component.
try MetaHopper plugin. it has Group Toggle component
It’s a big button that you group together with the desired components, then you set with right click for hide/show or enable/disable mode, and you turn on/off with left click
you don’t have something like that left-handed panel, but you can do it yourself with different group visualization. use a little fantasy and have fun
