Suggestion: Drawing projections referenced by Cplane
a while ago I gave the suggestion to have the Draft Angle analysis based on the Cplanes and it worked great! Thank you for implementing that!
But, here I am
It would be wonderful to be able to create projections for the Make2D command using Current or Named Cplanes!
This way it would be possible to create the lines for drafting without needing to move the objects out of position!
A even better implementation/improvement would be to have the Cplane reference and to include in the new Section tools as an option for the make2d command, similar as we have some options to create SubDs or SubD compatible curves in other commands, but this time, a Create curves as Dynamic Sections option!
InkedCapture_LI
I would like to hear what other users think about that :slight_smile:
