Suggestion - configuration option for blocks
In V9, I suggest adding a configuration option for blocks. For example, if I had a block for an aircraft wing. I would like to have a configuration option that shows the wind with the flaps in the retracted position or in the deployed configuration without having to create two separate blocks. A right clock on the block would bring up the configuration choices.
