Sudden loading issue from the 2nd parameter change
Hi there,
This afternoon, I encountered a sudden issue with one my model that has been connected to our Online e-commerce site for about 6 months as below:
Any 2nd parameter change would result in infinite loading
e.g : Change height no issue, change any parameter after that and it would try to load infinitely
※Same issue on both my website front end and also shapediver platform viewer
I tried changing the uploaded model with the issue to an open-link so I could share it with you guys, but after that I found that it entirely stopped loading for some reasons.
After that I reuploaded the exact same file and it works just fine, so I know it is not a file issue.
Any enlightenment or possible cause would be greatly appreciated.
https://www.shapediver.com/app/m/wEOCPem0FbOqjkbqGehBKWJowzKNiB
Looking at the model, it seems like a lot of heavy operations happen during gathering outputs. I cannot compare with how the model loaded earlier, but it was likely always slow at loading outputs, sometimes leading to time outs on the servers.
I suggest as a first step that you update your material and display components. You are using the old component (obsoleted since about 3 years). The glTF 2.0 Display and Material components should provide much better performance, and would likely solve the issue and make the model faster.
You could also review the response times of the service where you uploaded all the textures of your model, and try to optimize their sizes (some of them have unnecessary high resolutions).
If problems persist after those changes, please post the update model here for further review.
If the problem persists,
