Hi Everyone, I am trying to subtract a sphere surface from an extruded polyine and for some reason it’s not working, can someone help me with this please? thank you
Solid Difference.gh (13.1 KB)
I’m somewhat confused by why it fails, it works like this: Solid Difference.gh (20.8 KB)
I think maybe the reason is that you were sending your points through text panels and then back into points. You should never send data through a panel as it first converts the data into text and then back again into the original data. This conversion is not lossless in all cases. For numbers and points you may lose decimal precision.
thank you very much for the quick reply, and the solution too
