Subselection + displacement in v8
i’m following @BrianJ tutorial for Displacement using v8 instead of v7 but it seems subselection doesn’t work anymore. If I apply displacement to the hole polysrf it works but if i select only a part it doesn’t.
Anyone else with this problem?
Thanks in advance
[System info:
Rhino 8 SR8 2024-5-21 (Rhino 8, 8.8.24142.13001, Git hash:master @ cf2a36827c139ab301c2560ae9153ea7a926bdec)
License type: Comercial, build 2024-05-21
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.19
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\CommandTracker\7.0.8201.28462\CommandTracker.rhp “CommandTracker” 7.0.8201.28462
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
D:\00 RESOURCES\080_RH7\blockeditnew202310240119\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24142.13001
Hi @12Lab,
Try sub selecting the faces after displacement, where you don’t want it to disable the displacement property for just those. Any luck?
The behavior may have changed in the order you need to do it, I’ll check and file a bug if needed.
thanks a lot!
as you said the order changed, first i apply to the whole polysrf and then disable the parts i want “clean”
Yes, there’s a bug, and difference from v7, sorry! It works in v8 as I described but it’s a pain to deselect where you don’t want the displacement after. Filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-82114 Thanks for the report.
