Anyone else is having this issue updating Vray 2.0 scenes to Vray 3.0?
“Subpixel color mapping is on: rendered result may have incorrect brightness.”
Since there’s no “color mapping” option in new vray, any idea ??
Thanks!
Thanks!
Try this trick:
open the old scene
save the render settings to a file
open the vropt file with text editor or wordpad, search for the line with “clamp output”
set the value to 0 and save
Reload the render option file
<parameter handler="default"
listType="none" type="bool" name="clamp_output"
label="clamp_output">
**<value>0</value>**
1000 thanks!!
Have the same problem, but this solution did not resolve my issue. I still says the “Subpixel color mapping is on: rendered result may have incorrect brightness.”
I have tripple checked that the option file is the correct one.
Thanks
