Subobject Selection in blocks bug
If I create a block in V6 and then try to use subobject selection methods I have an issue with curves. I can select surfaces, solids, and extrusions just fine, but if I try to select one of those objects in the block, all curves get highlighted too. Similarly if I just try to subobject select a single curve in the block I also get the result of all curves being selected.
I am working with the December 5 BETA. Hopefully its an easy fix since this has worked in the past just fine.
Thanks
Ian
Hi Ian - thanks, I see something along these lines here as well - https://mcneel.myjetbrains.com/youtrack/issue/RH-42936
