Hi Ivan - I guess it makes sense to want to do this and it’s probably possible as well… But it might be very difficult to make it work as expected in every single case. Your case looks simple but you could attach a huge file with hidden layers and stuff as a block and … you’ll run into issues such as this one (RH-56722) where trimming with a block leads to unexpected results.
At any rate, I’ve put this feature request on the list as RH-57350.
Thanks,
thanks i know nesting and stuff makes even simple things overcomplex. but i guess maybe some simple logic could be applied to this particular one that subselection with booleans could/would pick any visible nested object within a block which is not locked and is solid.
principle is that what i see i can select
