SubDSweep1 failing and freezing
Whenever I try to perform SubDSweep1, the menu is acting up and the program freezes.
Sweep2 seems to fine, however.
As a workaround, you can try using -SubDSweep1 (hyphenated).
read more…
Hi @siavash.tohidi
You are probably using an older version
Install this version
https://files.mcneel.com/dujour/exe/20210406/rhino_en-us_7.6.21096.05001.exe
I will check it out and report.
