This created this surface from some curves and used boundary surface to then divide the domain, but it is not working.
Hi Cameron,
That’s because you are only dividing the mathematical domain of the surface, not the actual surface itself with lines/physical geometry.
You can feed that the domain divisions into a node like “IsoTrim” but that won’t respect your original surface geometry either.
Here’s an example of one way to divide the surface, someone on these forums probably has a better solution though and this topic comes up quite a bit.
20230530_Divide_Surface_Response_01a.gh (12.4 KB)
Thank you
You’re welcome!
