SubDivide Options please
I’ve been using T-Splines since 2011 and SubD since day 1 in WIP. I’m mainly working in R7.
TriRemesh, QuadRemesh and SubD is a great tool to convert 3D scans into Nurbs.
In most situations, I’m modeling SubD without creases. Currently the SubDivide command does a Catmull Clark subdivision and all creased edges / points stay where they are. Everything else is smoothened. That’s not what I want. I want to be able to use the SubDivide command like inserting loops and rings at once on all faces.
T-Splines had two options for subdivision, simple and exact. The naming was unclear.
I don’t think SubDivide should automatically do a Catmull Clark. It’s a nice option but in my opinion we should be able to choose in the command whether a face should only be split or split and smoothened. There are certain workarounds which are ok in some situations. However:
Could we please get the option to choose again?
SubDivide has been discussed in the following two topics:
V7 mesh SubDivide doesn’t smooth? - Serengeti (Rhino WIP) - McNeel Forum
Options/settings for Subdivide command in WIP - Bug? - Serengeti (Rhino WIP) - McNeel Forum
Hi @martinsiegrist
I’ve made my own little Grasshopper Player-thing for just that:
_GHP_SubDivide Mesh Cattmull-Clark.gh (6.2 KB)
-Jakob
Thanks I’ll give this a try.
Nevertheless I hope we will get the option back.
@dalelear on why the option was removed some time ago:
… what users want most of the time …
I’m using Rhino because I usually have all the options. Much in contrast to other software. Please keep it that way. Same thing with the Gumball.
Or @piac saves us and activates his old plugin again.
On the way I would like to report a bug in GH and Weavebird, → options in Catmull Clark Subdivisions component not worked.
I have a deep sense, that uncool cuts are being made in the Rhino core. :blush:, namely from Service Release to next SR
