are the quad remesh settings in rhino wip
yes i have already used the subd options in grasshopper on past occasions
Thanks!
With fatten the hard part is making nodes where each connection has the same number of sides. Otherwise you end up with struts needing to connect with different numbers of edges at either end, so you have to introduce triangles along their length and the subd structure gets a lot messier.
Now I have all-4-sided struts working though, increasing this to struts with multiples of 4 sides is pretty easy. Here’s with simple subdivision
but one potential advantage of using more sides I haven’t used here yet is that it should be possible to reduce the twist along the struts, since you have more options for how to match the rings at start and end.
This is way over my head, but from playing around with the node blend problem in manual drawing, I totally get that many circumstances force me to create triangle or penta faces in order to get good looking results.
The current version of fatten is pretty reliable for four way intersections, are you saying the new one is totally reliable or that it’s going to do even more?
The currently released version of fatten gives a horrible result for something like the node on the left in the image above where 6 skeleton edges come together, because it always tried to find one axis per node and arrange connections radially around this.
The new one doesn’t have this limitation.
Nice. Yes, the twisting in the current version is why I mostly used it on relatively simple lattices that I made by using various components from the Mesh+ “make” panel, applied to gently warped surfaces.
Very much looking forward to using the new version. My output for it is CNC routed wood, which presents a minor challenge in terms of how to break it down into parts, but the potential for what it can do in terms of building real world objects is really really cool.
@DanielPiker, can you please post that file. We need to 3D print this. It’s too epic to leave it as a screenshot experiment only
G
Here you are
ExampleModelsMashup.3dm (2.0 MB)
also - last shot didn’t show the triceratops on the trunk
-the human and triceratops heads have eye openings which would need to be closed for 3d printing
Oooh… it’s even an El Camino
Looks like a Lotus Europa to me. (I may be showing my age}. Lotus Europa - Wikipedia
Added: A S1/S2 Europa with the Renault engine based on the higher “sail panels”.
"Hyperfusion360 "
We don’t use that type of salty language around here…
Hey @DanielPiker.
Just out of interest: are your “fusion"-booleans based on this research?
Link
Cheers, Norbert
Hey @norbert_geelen
Indeed - that paper was an inspiration. I don’t exactly follow their approach, but it’s similar.
Thanks. Can’t wait to try it.
Hi
Is this tool in the new version?
Or not finished?
That good,
In ““Mehmixer””,…
I think there was something similar since 1783 … + - 1810?
hahaha
Do not hurry !
Yes, Meshmixer from Autodesk,…
but…cmon.
This is nothing like mesh mixer, because it is all about keeping a quad based topology.
This is why we can’t have nice things
Sorry,… very confused!
