SubD Sweep Match Rail Topology Direction?
So I am trying to create a subd sweep (gray) to join it to the purple subD. I don’t like how the direction of isocurves is not the same. Is there a way to fix this so that gray matches purple?
Hello- only after the fact with MatchSrf > Match target isaocurve direction, but this will be at best a partial fix in that only the second and possibly the third row of points will pay attention, so the isos will wiggle . Why do you want this match? - can you post the inputs to your surface?
Hi Pascal, thank you for the reply.
Just to clarify, this is all SubD geometry. I guess I assumed it is best if they match? Topology wise? Next step is to join these two SubDs into one.
Thanks for taking a look.
For Pascal.3dm (133.4 KB)
I was able to get a better match after some hard work in grasshopper, orientating each profile curve across the rail…
Hello- I see - I guess, ideally, if the input is SubD edges, the ‘Align to surface’ setting from the surface version of Sweep1 ought to be possible… I don’t know if it is , but I will add it to the heap.
RH-80459 SubDSweep1 - Align to surface
That would be awesome, thank you! :rocket:
