Is it possible to achieve a smooth transition in these situations? (maybe automatic?)
Right now there’s an odd kink happening.
Thanks!
Thanks!
You would need a parameter (expressed in percentage, for example) that allows you to set a region of influence at the crease (higher percentage = softer fold and greater area; lower percentage = sharper fold and smaller area of influence).
Or, as in case of blends, some editing points and curvature graph ?
Or, maybe even better, continuity by Position, Tangency, etc:
check this thread:
