When I select the top edges of a subd with Reflect and use the gumball to extrude, when I’m done random edges are selected and some of the original edges that I was extruding are deselected.
This only happens if I select at least one edge on the primary side, and some edges on the non-primary side are also selected. The number of random edges selected when the extrusion is complete is equal to the number of non-primary edges that were selected to extrude (but only if the same edge on the primary side is selected, I think.)
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\phcre\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\WoollyRhino\1.2.0\WoollyRhino.rhp “WoollyRhino” 1.2.0.0
