Hi
Did SubD from primitive SB box, tweaking shape, can’t select whole SubD object if “Display wire SubD”
is not check
Selection filter “Sub-Object” checked
Bye
Hi
is not check
Bye
Hello - I’m not sure I completely understand but as far as I can tell this works here:
If Sub-Objects is set in the selection filter and I ctr-Shift select a SubD. the entire subD is selected regardless of the ‘SubD Wires’ setting in the Display panel (if not in wireframe display mode of course).
