How to move an edge loop along the surface it’s on ?
Hi Thomas - what comes to mind is moving the control points associated with the edges along their control polygon. (`DragMode’ > ControlPolygon) Not quite the same but…
Hmm. When I do that, only one point moves on it’s control polygon. For instance the ones on the left are not.
On a SubD use the Slide command for that edgeloop.
NICE ! Thank you !
I knew that…
