Subd model with rendered front view graphic crashes with layer surface
with perspective of top view doesn’t make any problems with rendered view setting.
especially view with horizontal occurs graphic crush. how can i fix it
Please run the Rhino command _SystemInfo and post the result in a reply.
Also attach the file here for further investigation.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Educational, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [77% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-26-2024
Driver Version: 32.0.15.6590
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
13.3dm (17.8 MB)
You have a surface very far away from your buildings. That is messing up the AO calculations.
  1. Select all buildings in your view
  2. _Invert
  3. (optional) zoom out in top view until you see the selected surface
  4. Delete the surface. Notice that the Front view looks now correct.
edit: this is not a crash, but geometry does look unexpected. Above steps resolve the issue.
thank you so much. i’ve never thought of it. you are the best
