I have a model that no longer lets me pick edges, points or faces when holding down the command / shift. I think I’ve found a major bug in the SubD program. Any one else see this issue…
I know, I start another subd model and no trouble…I can send you my model and you tell me whats wrong…cant edit at all
sure
Here you go and thanks for the help…I’m new to SubD on Rhino, so I’m probably missing something obvious…thanks so much…here’s the model.
power tool test.3dm (285.2 KB)
i tried quad remesh and it works now
I’ll try that, but, I thought I’d save it the way it is and send it to McNeel…it should not have done that…
I tried it and it doesn’t work…it quad remeshes but loses all detail
I have no idea what that means…but others may encounter this issue and I’d like McNeel to look at it. If you’ve repaired it, could you send it back?
try another file format like 3dm
other than quadremesh i dont have any another solution mcneel will surely know what to do
Thanks for your help…this is weird to say the least. Quadmesh didn’t work very well as all creases and accentuations disappeared. We’ll see what McNeel has to say…thanks for trying.
hey @Jim_Girard , your model is grouped.
simply run the ungroup command a few time and your edge selection will come back.
i didnt even know one could group subDs and one object or does subd count as one object?
there is always something new to learn
