is there a way to insert a certain number of edges in between two edges in subd, when I want to insert edge and write and amount x it only adds one edge that is x unit away from the other edge, what I want is to add x number of edges in between two edges
bridge
one approach would be to use _bridge
this command allows to enter the amount of segements
maybe with some helper-SubD-Faces
delete the inital face
redraw it with _bridge and use the desired amount of segements
optional delete the helper-Face
subDPlane
… allows to draw a planar surface with X-Count by Y-Count faces.
of course both or one value can be 1.
does this help ?
if not - what s the context of your question ?
kind regards - tom
This is on the list as RH-56109 InsertEdge option needed for multiple edges at once
I’ve added this thread to it.
glad its on the list!!! it would be very useful to have it since it helps a lot in maya
