Good morning.
I’m wondering if there is any way to perpendicular extrude some faces at the same time. It seems that the only thing I can do is extrude them along X-Y-Z axis or freely.
Thanks in advance.
Good morning.
Thanks in advance.
Thanks, this is filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-49859 . You can in the meantime use ExtractControlPolygon on the SubD and then use ExtrudeMesh with basis set to UVN and then enter a distance value. ToSubD after that to get back to a SubD. Ideally ExtrudeSubD will also have a normal option after a few things get hooked up. I added your vote to the feature request.
