SubD extrusion with symmetry bug
I’m having an issue when I extrude with the gumball this edge.
260825 - SubD extrusion with simmetry issue.3dm (142.6 KB)
After creating the extrusion it selects one side correctly and random edges on the other side.
The subd geometry has symmetry enabled, but if you remove it, it works as expected.
BETA
(9.0.26230.12303
It might take a while to fix this one and others that depend on stable indexing in the children motifs of a symmetrical SubD, unfortunately. Fixing how SubD subobjects are indexed in the children motifs of a SubD is a deep change in the SubD core, and is very hard to do with our current “symmetrization” process.
RH-98048 ExtrudeSubD: With symmetry, post-command selection is messed up
