I wanted to play around with a SubD and its edge indices in Grasshopper.
Once an edge of a referenced SubD is moved, the SubDEdges component goes red. Same thing happens when the whole SubD is moved just with Grasshopper components, unless the factor of the transformation is 0.
@pascal for me it only worked when the subd component was set to be visible. If I hide the geometry or remove that component or the datadam it turns red when moving the slider.
Hi Gijs - I just blindly hooked up a SubD to a SubDEdges compment - in a brand new GH and the thing has no output - fire-engine red… looks wrong to me, I’ll make a YT item and David can set me straight if I am doing it all wrong…
