Subd degenerate control net edge
I’ve been working on roughly modeling out some massing and windows in SubD. I got this error while trying to insert an edge loop into the mass:
degenerate control net edge (417)
Is anyone aware of how to solve this? CullDegenerateMeshFaces obviously won’t work unless I convert to mesh and then back to SubD, but it seems that there should be a more elegant solution.
house detail.3dm (182.8 KB)
Hi @Maria_Mendoza_Blanco
That edge is actually two edges on top of each other - use stitch to merge them into one. Start by moving one of the edges slightly, so that they are no longer co-adjacent, and then run Stitch to merge them.
HTH, Jakob
That worked, thank you so much!
