SubD Custom Rhino Object
Is there any plan to add a CustomObject class for SubDObject in Rhino 7?
Thanks in advance
Kind Regards
Will
Hi @Harper,
I’ve added your request to the heap - https://mcneel.myjetbrains.com/youtrack/issue/RH-61906
Just curious, why do you need this?
– Dale
Hi @dale,
Thanks a lot! I use the overridden methods to capture the transforms, morphs and other info from overrides to keep properties of my plugin objects.
Kind Regards
Will
Hi @Harper,
You should be able to do this today just using event handlers.
– Dale
