Subd Crease weight of 100% is not a sharp crease
I’m trying to have a variable crease that goes from sharp to blunt. I’m able to achieve a variable crease for this, but at 100% weight it isn`t as sharp as when just using a regular crease. Is this a known issue? Is there a solution?
Thank you,
Sam
hi @samlochner
Those two are not compatible. Under the hood, there is no crease at all when using a soft crease. Even at 100% it is still going to be a G2 rounded corner.
That’s too bad. I wonder if the 100% crease can be made sharper somehow, maybe by higher face density…
