Sub-D Manipulation inside Grasshopper possible?
Hello Mcneel team,
I’m creating a Sub-d shape inside Grasshopper.
I’d like to know if it is possible to manipulate edges ( smooth, interior) to move them in the Z axes inside GH? or it can only be done in Rhino?
If yes, what components will I use to select the edges? I’ve been trying the usual selection components for nurbs objects, but they do not work for Sub-d objects
Thanks.
Are you aware of the search function in Grasshopper
I have tried SubD Edges, but it only gives me data. First I have to create a list of item numbers manually, but if I use more U or V iterations, selection changes.
Second, I can only isolate this items, nothing happens to the SubD object when I move selected items up in the Z axes.
I’m not sure if I’m clear… I want to pull edges form the SubD object just like inside Rhino,
SO far what I can research is that is not possible. I wonder what are the SubD components for then?
I’ve also tried selecting edges by Curve Closest Point , taking 6 curves as reference, but it doesn’t work either.
Thanks Martin
Here’s one way how you can modify a control polygon of a SubD:
I’m using the vertex tags to filter the mesh vertices and then move the creased points. Keep in mind creased edges are unwelded and there are two vertices at each creased point.
subd-modify.gh (22.6 KB)
Thanks! I will try it.
