is here a grasshopper professional who would like to help a stupid student getting his grade in grasshopper course. Got a nice idea but I can’t make it like I want to.
I would appreciate a Zoom Meeting … Somebody there?
that is probably not a every smart approach to get your answers, specifically when you write that its for an exam
still if you elaborate on what you are trying to achieve, with some sketches or images and even better with an additional grasshopper file with some geometry or some components to get started, maybe somebody is interested.
At least it’s honest! It sounds he is even going to pay. So why not. How many students pass exames by downloading definitions, even claiming being pro… ? 90%?
No, its not an exam, and I got a good structure for the my project. But there are so many difficulties.
See Attachment…Rautenmuster.gh (16.7 KB)
I need a thickness of this elements.
Maybe I don’t understand, it is easy to extrude these surfaces. As you see the normals are pointing in different directions, you can fix it in the initial geometry or with Flip Plane.
It’s amazing how simple it looks, when you do it. My “code” was much longer and with no clear structure. I have to admit, that I do not comprehend every steps you did.
How can I make the structure close the backside of the Pavillon? So there should be a angle of 90 degrees to vertical.
I also have to make a bounding box out of the Pavillons size, so that I can change the structure only in between the “limit” of the frame. May you see the rendering to understand what I want…
The side with the arrows should be closed with the structure. The structure should be limited bei the Frame, so that my parameters only change the design in between the frame.
Yes, because it requires calculating the longer ellipse dimension (‘R1’) and the ‘Y Factor’ so that both fit evenly in the available box/frame space, based on the number of repetitions in each direction.
Thats right.
I would like to understand what I do. If I analyze and comprehend what you did there, I don’t think its cheating. Its learning I will not do the copy and past thing.
I think that roof has to be enough for my grade
Thank you so much for your time!
