I’m currently struggling with a model I try to make to draw a parametric ski in Grasshoper. I try to model it through the intersection of 2 Breps, but it failed. I’ve tried every option I could find relevant but I’ve always encountred a problem.
As I’m still a beginer in Grasshoper, I’ll be really greatful if somebody would like to spend some times on my issue. Unfortunatly it’s in french, but I can help to translate if needed.
Just one thing, when I opened the file I didn’t get the actuel result you have, there’s still one of the breps which is still visible, the one which is called “forme ski”, whereas everything is set on preview off do you know why?
J’avais pourtant tout mis en preview off et ça ne fonctionnait toujours pas, mais j’ai résolu le problème en changeant le type de transformation entre solide. En revanche il y a un truc que je ne m’explique tjs pas c’est que pour certaine valeur de certains paramètres le volume résultant n’est pas créé. Je pense que ça vient de a fonction arc.
