Hi
Looking at Revit Shafts & Openings.
Shaft Openings Profile is just not the profile but also with the cross hairs… Also have found geometry of the Shaft… is not a full brep of the shaft that is cutting floors…
I was struggling to find all Structural Openings…
However, this worked. Selecting the Opening and finding the category.
Not sure if there is a better way to find all Structural Openings in Revit?
Japhy
(Japhy)
November 14, 2022, 1:16pm
2
Hi Christopher,
A bounding box will get you the extent of the Shaft Opening.
Try sorting the subcategories of the line work after getting the Element Dependents.
Thanks Japhy…
If you have a shaft with multi shafts in the one Revit Element Shaft - Bounding Box will Create 1 box around all Shafts… Not really Ideal.
Is there a way to get element geometry from shafts? Single Brep per Shaft.
Regards Chris Pires
Japhy
(Japhy)
November 16, 2022, 4:34pm
4
Here a geometry driven solution. I’ll see if we can do something better via the Revit API.
ShaftOpenings.gh (9.6 KB)
Nice Work around @Japhy . Thanks
