Structural Column - Attachment TOP & Bottom
Is it possible to handle structural column attachments within RiR?
Yes you can find these input options in Add Column component of RIR
I think what Chris asked was about handling column attachments at both ends of column to element (floor/beam), not to Levels.
The parameter is not available in inspect parameter as the parameter gets active only when an attachment is made. Instead use the Built-In-Parameter for all such parameter queries. Attachment, coping, cutback, etc can be accessed from this list
Nice one Malthesh! Thanks! That is the solution!!
We are now creating a user object to show the results of attached & unattached. (True/False)
