Hey Forum!
My professor has set me the task to build a script for topological optimization from scratch - so nothing pre-built from an addon.
My Plan is to have a box, which represents the beam to be optimized, then voxelise it, and then let galapagos take away every voxel which isn’t needed. That’s worked allright so far, with one small problem: I couldn’t find any Plugin which allows me to structurally analyse the Brep.
My simple question is: Is there a Plugin, which i can attach to my Brep, add loads and materials and it will automatically compute whether the Brep will hold up or not?
I hope, you’ve understood my question - the GH file is attached, with the last solution I’ve came up with.
Thank you for your support,
regards, Jonas
Adaptive Brücke test 5_4.gh (15.8 KB)
