I have an object in my model of type StringList with the choices: [“Full Lenght”, “Half Lenght”, “First Met Cut Out”, “First Ray Cut Out”, “Morton’s Extension”]
Im not sure how to update my model with parameter of this type. I tried to intert string list, or even an index, since default values is 0.
The name of the parameter (it’s not called ‘List’, but ‘Insole Model’) but I guess you changed it for the example.
Your double-quotes were not working for me, not sure how you formatted them. I replaced them with single quotes
If you give the function the current value of the parameter (in your example, if the index is already set to 0 before you call the function), then it will abort and not do any update of course.
I was using the previous model, so I had List as parameter, but the problem was in the model, was not working. Now it works with the latest model.
Thank you.
