Stringing Multiple Hops Together
I’ve made multiple Hops and now I’ve made a script from them that I’m trying to run on Rhino Compute on a VM. It appears to work fine in Grasshopper connected to my VM but not when I call it via JavaScript. Can anyone see what’s potentially wrong (screenshot and code attached).
// Imports
function ProcessButton() {
  const rhinoRef = useRef(null);
  const definitionRef = useRef(null);
// Rhino setup
  useEffect(() => {
    (async () => {
      const rhino = await window.rhino3dm();
      rhinoRef.current = rhino;
      RhinoCompute.url = import.meta.env.VITE_RHINO_COMPUTE_URL;
      RhinoCompute.apiKey = import.meta.env.VITE_RHINO_COMPUTE_API_KEY;
      RhinoCompute.authToken = import.meta.env.VITE_RHINO_COMPUTE_AUTH_TOKEN;
      const definition = new Uint8Array(
        await (await fetch("/definitions/building.gh")).arrayBuffer()
      definitionRef.current = definition;
  const handlePress = async () => {
// Using Rhino Compute
    const trees = [new RhinoCompute.Grasshopper.DataTree("geojson")];
    trees[0].append([0], [JSON.stringify(geojson)]);
    console.log("Sending data to Rhino.Compute");
    console.log("Trees:", trees);
    const result = await RhinoCompute.Grasshopper.evaluateDefinition(
      definitionRef.current,
      trees
    const meshes = Object.values(result.values[0].InnerTree)
      .flat()
      .map((entry) =>
        rhinoRef.current.CommonObject.decode(JSON.parse(entry.data))
    const loader = new THREE.BufferGeometryLoader();
    const exporter = new OBJExporter();
    const objs = meshes.map((mesh, index) => {
      const geometry = loader.parse(mesh.toThreejsJSON());
      const threeMesh = new THREE.Mesh(geometry);
      threeMesh.name = `mesh-${index}`;
      return exporter.parse(threeMesh);
    console.log("OBJs:", objs);
    setOBJs(objs);
  return <Button onPress={handlePress}>Process</Button>;
export default ProcessButton;
Thanks!
