This particular design didn’t work. I missed the hole by 7mm. So I need to stretch or push-pull the bottom leg of this solid 7mm in Rhino 8 at the red line. I don’t want to redraw it if possible. Any suggestions are appreciated.
Thanks,
-JW
StandOff.3dm (794.1 KB)
SolidPtOn seems to work okay for this. A simple shape like that you can just chop it and fill in the gap with planes and MergeAllCoplanarFaces it, of course.
Wow, thanks very much, very cool. I didn’t even know the command existed. How to you turn the points off after I stretched it 7mm?
Just the same as regular control points.
The stretch command should do exactly this. I noticed it makes a pretty messy surface on the bottom in your example though.
