Stretch mental block
This is an embarrassing question, because it should be so simple, but I just can’t seem to master it.
I need to stretch this portion of this assembly from 1.475 to 1.600 (+.125), but I cannot do without contorting the thickness or other part features. What is the trick to this?
Thanks,
Frank
Stretch.3dm (6.0 MB)
Hi Frank - yeah… it is not super straightforward I guess. I assume you want to leave the radii alone and only stretch the flat bit:
Try this: Ctrl-Shift window select the outer bits:
Turn on Gumball and click on the red arrow, enter .125 and Enter:
Wow, I didn’t expect that. It works perfectly. I haven’t had an excuse to use Gumball…until now.
Thanks Pascal!
Frank
Hi Frank - Gumball is one way that is convenient in this case, but Move works as well.
