nancy2
(Nancy)
September 28, 2021, 11:31am
1
I am working on a stretch fabric lampshade using same construction as attached images
I’ve got my metal frame in place but not sure which tools (and in which order) to use to create the stretch material over wire. Any guidance please?
Thanks, Nancy
pascal
(Pascal Golay)
September 28, 2021, 4:03pm
2
Hi Nancy - please post a file with one of the frames or a couple of sections of it, I’ll take a look . If the work is confidential, please send to tech@mcneel.com with a link back to this topic in your comments.
nancy2
(Nancy)
September 28, 2021, 6:43pm
3
Hi Pascal,
Have sent file with link!
Thank you!
Nancy
You can simulate this with Kangaroo
nancy2
(Nancy)
September 28, 2021, 7:08pm
5
Unfortunately I don’t have Kangaroo (or know how to use it) .
diff-arch
(diff-arch)
September 28, 2021, 7:39pm
7
Kangaroo comes with Rhino. As Martin mentioned, you can pretty easily build a lamp shade generator with Grasshopper and Kangaroo.
The attached definition works for convex frame sections.
You can set a separate tension for the mesh and the naked edges.
kangaroo_stretchy_fabric_light.gh (37.3 KB)
nancy2
(Nancy)
September 29, 2021, 8:30am
9
Thanks for this Martin… I’ll have to learn Grasshopper / Kangaroo if/when I get time!
nancy2
(Nancy)
September 29, 2021, 8:33am
10
Ok, thanks. I clearly have lots to learn (just need to split myself in two to do it )!
There’s really nothing to stop you from doing this in stock Rhino! You can simply:
Draw one of the wires that form the frame - use nice simple/clean curves - ideally single span.
Use ArrayPolar to populate the rest of the wires.
Loft between two adjacent wires, use the Straight Sections and Do Not Simplify
Use ChangeDegree to change the surface across the loft to Degree 2 from Degree 1.
Grab the center verts and push them inwards.
ArrayPolar the result.
Blend or Fillet the sharp edge between adjacent patches.
Literally hanging over my head as I type this:
-Sky
pascal
(Pascal Golay)
September 29, 2021, 5:08pm
12
Yep - something like that is exactly what we came up with for the user-
StretchFabric.3dm (313.5 KB)
davidcockey
(David Cockey)
September 29, 2021, 5:17pm
13
Two different approaches:
a) Create a surface with the desired shape, using knowledge of what the shape should be. See SkyG’s and Pascal’s posts for examples.
b) Estimate the shape which will result using the geometry constraints and the material characteristics. I assume this is what Martin is suggesting. This is a much more complex problem.
As always there are many ways …
