I would like to ask if there is a way to make a curve go around another curve. From the screenshot you can see the orange lines (tiles) must go around a wall (black). I know I can use the stretch command but this will change the geometry of the tile in one direction only and I will use the whole section of the tile overlapping the wall. Is there a quick way to make the tile block bend along the wall? If it will make a difference between each tile there is a 2mm gap.
Regards,
