Any news about this (still a) problem?
Philip
Philip
I can confirm the strange behaviour. I am experiencing the different length number appearing when trying to measure the geometry with using this tool next to the cursor. Hope I will manage to get some video/ screenshots later.
You can probably repeat this - so… is it fixable?
Philip
I do not see this in the clip - if the length shows at all it seems to be consistent, am I correct?
@petumatr - do you see the intermittent tooltips?
Yes, seen that too.
Actually, no, it’s not consistent - the numbers can vary when you move the cursor near the snapping point (as @petumatr said). I didn’t catch that behaviour when making the video though…
Philip
Hm, I dont see intermittent tooltips, just the issue with incorrect length. It happens only for the first time when trying to measure the geometry.
I was finally able to get this odd behaviour on video. It’s very hard to repeat - I had to try many times…
I’ll send the file directly to McNeel.
The distance is supposed to be 12 mm.
Philip
Ah yes Philip,
thats exactly what I experienced as well. Good job with getting this on video.
Petr
This is still a problem…
Philip
Can confirm here as well…
I have the same problem as well…
I don’t know for you guys: For me it gets worse if the file is larger and if I am moving the mouse quite fast: then it happens about 1/3 of the time.
Any news?
that happens a lot with me… (multiple times per day)
it’s become ‘measure twice cut once’.
but yeah, will be nice for this bug to be squashed
Yep…
Philip
Hmmm, strange… Here it happens all the time.
Philip
i tried repeating the steps leading up to the behavior about 5 times today but it doesn’t seem repeatable once it fixes itself… (which it always does upon a 2nd attempt)
a bug squasher’s nightmare i suppose but from a user POV, it appears to happen randomly
@dan - I can reproduce the wrong value issue here with the file that Philip sent on September 24th. And as @nickboewing wrote …
… it’s about 1/3 of the time.
Reported as RH-55744.
I can’t reproduce the issue where nothing appears in the tooltip.
