Strange SubD bug, object disappears visually, still can be selected
Hi, think I found a bug in R7
I created a new Subd object by copying faces from another part. I thickened it and now when I try to edit it in any way, move edge/face etc it vanishes. First I thought I accidently hid it but after some testing it just disappears as soon as I release the mouse button after a transformation or delete. It can be selected again with select all. It shows in the command line that 1 object was selected but I can’t get it to appear again with Show objects but If I do a ctrl+z it reappears.
I have the latest windows 11, Rhino 7 and Nvidia Drivers.
weird.3dm (197.5 KB)
System info:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 12-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.50
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2024
Driver Version: 31.0.15.5350
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
I narrowed it down a bit, I rebuilt the object and something happens when I do Offset Subd if I offset outwards its ok, If I do it inwards it becomes this bugged thingy. I also reduced it down to one face, same issue and I made an example file whith the un-offsetted face and one offsetted in one direction and one in the other that bugs out.
weird2.3dm (148.8 KB)
I am seeing the same weird behavior here-
I’d need to loop in @pierrec or @dalelear to take a peek at this and see what I’m missing as to why this is happening.
RH-85371 removing creases makes parts disappear. v7 -37
