The stairs are not correct
The stairs are not correct.3dm (363.6 KB)
Hi Jon!
The issue is related to the high tolerance value that you are using on the document.
Make sure you always have as maximum 1 mm.
After you change the value select the stair and run _vaUpdate.
There may be still some issues related to the landings and treads but we are already working on them.
Regards,
thanks !
This is one of the known issues that we are already working on.
