Strange Offsets
I am suddenly getting offset curves looking like this:
Has some setting gotten screwed up on my end?
Two possibilities:
Option InCplane=Yes and one or more curve segments are not parallel to the Cplane
-or-
Option InCplane=No and the curves are not planar
This is not a bug. Rather it is how the geometry of offsetting curves works.
Upload a .3dm file with an example curve if neither of the above situations applies.
Check if you have the Trim option in _Offset set to No. If so, change it to Yes. Having it set to No gives corners like these.
HTH
Jeremy
Thx, that was it. I knew it had to be some options that I never use got set.
